Can you help me? Shock pistons and bladders
Hi guys,
I'm looking to order some shock parts for my Lightning Stadium PRO-R Truggy but I can't seem to find what I'm after in the UK.
I am just after the shock pistons and shock bladders (pressure caps). (1 of the pistons broke and 1 of the bladders has a small hole)
The shock piston's specs are:
12mm OD
2.55mm thick
2.50mm ID
2 holes
Held on by a nut onto the shock shaft.
The shock bladder's approx specs are:
Black rubber
14mm OD
5mm thick
Does anyone know of a brand other than HB which will work?
I am not really looking to buy a complete suspension as everything else is great.
Laurence
12mm OD
2.55mm thick
2.50mm ID
2 holes
Black rubber
14mm OD
5mm thick
Laurence
Thanks larryf333! I found the bladders there but they don't seem to have the pistons I'm after
![Frown](images/smilies/frown.gif)
