HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Steering Problem
Old 11-19-2006, 04:11 PM
SpikeX
SpikeX's Avatar
Default Steering Problem
When I adjust the steering trim so that my truck goes straight ahead in one direction, and I turn it around to face me and gun the throttle, it will veer off to one side. I have checked the tie rods and they seem to be at equal lengths apart.
For example, I do a high-speed run in one direction, and the steering is perfectly centred. When I come back the other way, the steering will be way off and I have to turn a lot to keep the truck going straight.
Can someone please help me?
Old 11-19-2006, 04:17 PM
benzzyo5
benzzyo5's Avatar
Default RE: Steering Problem
is it way off? this happens to me but it's not a big dea; because it's only slight
Old 11-19-2006, 05:08 PM
46u
46u's Avatar
How do you have your steering servo saver adjusted? Sounds like it might be to loose.
Old 11-19-2006, 07:39 PM
benzzyo5
benzzyo5's Avatar
also just another thought make sure that your using the right servo horn it can be slipping or skipping on the servo when u turn, this happened to me before.
Old 11-19-2006, 08:31 PM
46u
46u's Avatar
ORIGINAL: benzzyo5
Very good recommendation as I had two on my Savage strip do to the screw coming a little loose until I got in to the habit of periodically make sure the screw was tight.
Old 11-19-2006, 08:33 PM
benzzyo5
benzzyo5's Avatar
same here. alot of the time i just lose the screw
Old 11-19-2006, 08:44 PM
46u
46u's Avatar
I never lost the screw but it does not have to get very loose to strip the servo horn.
Old 11-19-2006, 09:52 PM
benzzyo5
benzzyo5's Avatar
yup they don't have to get that lose, but i frequently check mine now.
Old 11-20-2006, 02:31 PM
SpikeX
SpikeX's Avatar
I checked my car just now and it turns out that one of the screws are loose. However, I cannot loosen one of the screws that hold the skid plate to the servo saver. I have tried heat, bit it just won't loosen...
Old 11-20-2006, 03:16 PM
benzzyo5
benzzyo5's Avatar
get a battery powered drill and use that be very carfull u don't stripp the screw. it there is a clutch on it set that. or ask your dad for help he can probably get it out, but in my savage 25 i didn't have to take out the skidplate to tighten the screw i just drilled a hole on the bottom so i can fit a screw driver through. and so it's even with the screw so i don't stripp it
Old 11-20-2006, 04:06 PM
kurtf5
kurtf5's Avatar
ORIGINAL: benzzyo5
Yea, or you can get a screwdriver that fits, and get some pliars and clamp those on the handle of the screwdriver (if its small enough) and crank it round like that. I often do it that way, just to snap the loctite loose.
Old 11-20-2006, 05:04 PM
benzzyo5
benzzyo5's Avatar
i'm talking about using the drill on the skidplate screw. don't use a drill on the servo screw, u might screw up the servo
