help with engine!??
CA, AMERICAN SAMOA (USA)
help with engine!??
hey...i want to replace the picco 12 in my rc10gt because its bumpstart with a pullstart os engine......and these cranks look different......whats the difference? can i run both?
RE: help with engine!??
The cranks are indeed different and you won't be able to fit the clutch if you get the wrong one.
I forget off the top of my head what kind of crank the GT uses (fairly sure it the short threaded one) - take a look at the engine and get the same kind of crank!
I think its called an SG crank, between the photos the CV will probably work, but not the TZ. Also sometimes the flywheel can not fit on different engines depending on the angle of the carb. I have an AE15 pull start engine and replace it with an OS12 TR but the flywheel from the AE15 was too big and is touching the carb body so i have to get a smaller flywheel.
