Is the overall length on a canister setup critical? In other words if the factory header and canister is to long for the application is it OK to cut the header to make the unit fit? I know with a tune pipe setup overall length can be critical.
Depends on the cans, call DA and they can tell you the shortest header length you can use with a particular can. What airframe/cans are you trying to fit?
