is servo saver needed?
ID, IRELAND
hi again guys,got two new servos today for steering and throttle,my question is,will it be better to fit new servo without the saver?
will it make a difference?
NC
RE: is servo saver needed?
Unless you have an original Savage 21 or one of the first Savage 25s, then your truck has a cam type servo saver built into one of the steering posts, which is much better than a servo mounted saver.
I liked the stock throttle/brake servo saver setup myself, and I have just recently swapped it out again for the "Ofna linkage mod" setup... but only because I relocated the servo for a midtank conversion. I had done it previously but I actually switched back after breaking a servo arm in a wreck because I didn't see the advantage compared to a properly set stock setup.
