Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
CX2 Heli: Important Blade Selection Tips
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 12-09-2009, 07:25 PM
gdavis9999
Default CX2 Heli: Important Blade Selection Tips
After a lot of trail and error, I have discovered some interesting things about the stock eFlight blades. Some of this has been covered in forums, but I wanted to put this together with pictures. I hope this is helpful to you.
When your blades break and you replace them, use the following steps to maximize the performance of your heli.
I discovered that most stock eFlight blades vary in both weight and pitch. You need to find two blades that are similar in both respects get the best performance. This is unfortunate, but a result of mass production to keep the cost down.
BEFORE MOUNTING THE BLADE:
Make sure it's the right blade
First be sure you are two lower or two upper blades. They rotate in opposite directions yet still have upwards thrust , so the leading and trailing edges are reversed. If you get them mixed up on your bench, the blades with the larger balls are the upper blades, the smaller balls are the lower blades.
Check the weight
Pairing blades of unequal weight will cause vibration of the rotor shaft. This is obvious at lower throttle positions when the heli is on the table, as the shaft and body will shake. In the air, the tail will vibrate. To avoid this, be sure your blades are balanced. Snap two blades together and balance them on their balls with two cups. They should balance pretty close to horizontal. Keep the heavy and light blades in different bags for easier selection next time. Mark them with an "H" and "L".
Check the pitch
Pairing blades of unequal pitch causes all sorts of issues. I have experienced TBE (toilet bowl effect), vibration, and even not being able to develop enough thrust to take off! The flatter the blade the less lift it has. Blades with more pitch have more lift. Place the blade on a table, with the tip pointing towards you. Look at the trailing edge. It's obvious that some blades have more pitch. Match blades with the same pitch, and the ones that are almost flat I discard, you simply need the curvature to develop thrust!
Lastly, with your blades off, check to be sure your outer and inner rotor shafts, and flybar, are not bent. This is important before mounting the blades in the next step. Throttle up just enough to rotate the shaft. It should have little to no wobble (keep in mind this is a mass produced model, so it's never going to be perfect). If there is wobble, you may need an new outer shaft. You can find details on how to do this from other postings (you need to be sure to correctly reinstall retaining collars, bushings, and other items in the right positions and orientations). To check the inner shaft, remove the drive gear on the bottom of the heli (two set screws) and pull it out from the top rotor head. Roll it on the edge of a level table. It should be not wobble and the plastic drive gear should also spin mostly in line. Lastly check the flybar. It's critical it's as straight as possible.
AFTER MOUNTING BLADES:
Check the alignment of the blades. Throttle up 75% and look at the heli from the side (I wear goggles, I value my eyes just in case a blade seperates). Look at the tips of the blades. The two sets of blades should each rotate in a plane. The room lighting needs to be right.
- upper blade
If you see two planes, that means either one blade is higher than the other due to unequal pitches, the flybar is not balanced, or both. Try the flybar first since you already choose two blades with the same pitch. The flybar should be straight. Then remove the flybar linkage from the large ball on the blade. Give it one turn either clockwise of counterclockwise. Put back on, did it get better? If not, go the opposite direction. Adjust until the blade is rotating in the same plane.
- lower blade
If you see two planes, that means either one blade is higher than the other due to unequal pitches. Go back and select another pair of blades with the same pitch. If you have TBE or little lift, choose a set of weight and pitch paired blades with more pitch.
Note: you will notice that replacing blades, especially the lower blades, may cause the heli to drift in the yaw direction (it will slowly spin in one direction of the other). This is normal due to the pitch differences in the blade sets, and you can you trim it out with the transmitter, or using the mixing POT on the helicopter.
ID:	1330889   Click image for larger version
ID:	1330890   Click image for larger version
ID:	1330891   Click image for larger version
Old 12-26-2009, 04:01 PM
sunco1
sunco1's Avatar
Default RE: CX2 Heli: Important Blade Selection Tips
Nice information man
Old 12-27-2009, 11:57 AM
res3567
Wow! Thank you! You just may have solved the mystery of why my heli issoo sick,,,, I have replaced gears and motors and I DID have the bladeson backwards LOL! But now it does vibrate and the motors are screaming louder than ususall and I never thought to check that....
THANKS MAN!!!!
Old 04-08-2010, 08:14 PM
gdavis9999
Now that I have learned more about my CX2 I have some more information that may be helpful to you.
It's hard to find two blades that balance well (between the cups). As others have suggested on this forum, use a small piece of tape on the underside of the lighter blade. If it's still not enough weight, either put another piece on or move it towards the tip (away from the root of the blade).
I have gone though A LOT of upper and lower blades, so I have made notes and noticed something else:
- blades with higher pitch cause the heli to climb faster when you punch the throttle. The reason for this is obvious. But because high pitch blades cut into the air more, they also cause more counter rotational torque (in the opposite direction of the blade movement). For example, the lower blade rotates clockwise and there will be more counter rotation in the counter-clockwise direction with a higher pitched blade. So more mixing has to be used be allow the upper blade to compensate. This means turning the 3-in-1 mixing pot clockwise which slows the lower blade (relative to the top blade). If you get a pair of blades that have extreme pitch, you have to almost max out the mixing POT to keep the heli from rotating counter-clockwise. From a full battery to a LVC battery, you have to keep moving the TX yaw trim to the right to balance the heli.
Following this so far?
- blades with lower pitch do the opposite, they present less counter rotational torque. So less aggressive mixing is required. It's much easier to balance the heli in the X axis as the battery drains. However I do notice more blade strikes with lower pitch blades. This is probably due to the upper blade not being pulled up as hard due to the lower pitch.
All this due to the variance of the mass-produced upper and lower blades. I wish they were more consistent.
