ENYA 1.55 R - Blown Cylinder Head Cover
My Feedback: (9)
Twice now I've have this engine blow a hole in the cover. At the same time it has sheared off the valve locker screw. The first time I thought it was a fluke. But now I figure there must be something wrong. Can anyone suggest what might cause this?
TIA
TIA
RE: ENYA 1.55 R - Blown Cylinder Head Cover
Jerry:
You could use the Saito FA-150 rockers and adjuster screws, never seen one if them fail. Of course to adapt them you'd want to use all the rest of the Saito engine too.
Haw.
Seriously, the Enya is a good engine, you must be mistreating it in some way to have the repeat failure, and most likely you don't have enough prop on it as hobbsy said.
Bill.
Haw.
Bill.
