Jet Cat P-100 RX w/intermittent startup & flame out trouble after a few runs
My Feedback: (18)
Hello,
Posting this in this forum as well.
I have a P100-RX which will run pretty well for 1 to 3 flights, then it starts to fail to startup or won't ramp up cleanly.
Two different symptoms, probably related:
Things we have tried w/mixed results:
I'm now losing confidence in the setup, we all know what it's like to fly doubting the setup, I'm on the verge of grounding the plane at this point, any help would be appreciated.
Regards.
- It will start, Stabilize and learn low. When you try to increase the throttle it will hesitate and ultimately die with a "LowRPM" off code.
- It will start and begin to ramp up but it will flame out while at "Stabil". Off code is "LowRPM"
- Checked fuel system, looks ok.
- Restart with GSU in manual and manually run up the throttle slowly until we reach full. (appears to work but I'm not 100% confident, symptoms have reemerged)
- Restart and relearn RC. (appeared to have worked once when it was dying, but then it didn't work when we tried it on an other day when it was dying.
- Set IdleThrResponse to : SLOW & set FullThrResponse to : Normal. (Also appeared to have worked and ran great for 4-5 runs. On the next trip to the field the symptoms reemerged. It's been really really hot and humid, I was advised this helps. It helped kind of, but not really.
Regards.
