Ideal location to mount Jet Cat Cock valve?
where is the ideal place to install the valve? Is it after the fuel pump but before the solonoids? or where the fuel enters the UAT? or any else location. Also Is it better to get teh jet cat or festo w/ 6mm? thanks.
RE: Ideal location to mount Jet Cat Cock valve?
After the pump, if you wish to use it in an emergency to shut down a runaway you do not want to wait for the UAT to empty and you want to be able to stop the flow from the pump.
Mike
Mike
