Saito FG 36 question
Old 08-23-2009, 05:01 PM
TravelairR
My Feedback: (7)
Default Saito FG 36 question
I have a question about the FG 36 that I can't find addressed in the manual. Is the typical fuel tank pick up line large enough to supply fuel to the carb. The line on the carb itself is larger than the pick up line that comes with the fuel tank. I think the standard line is 1/8 inch tubing but it looks like the carb fuel barb is about 3/16. Should I put a larger pick up line and clunk line on the tank or will the standard clunk and fuel line supply enough fuel?
Harry
Old 09-11-2009, 01:25 AM
joejoe923
Default RE: Saito FG 36 question
Did you get an answer to this?
Old 09-11-2009, 06:14 AM
w8ye
w8ye's Avatar
The engine's fuel consumption volume doesn't warrant larger line
Old 09-11-2009, 08:08 AM
TravelairR
My Feedback: (7)
Thank You, I came to that conclussion after I thought about it, the gas engines consume much less gas than glow engines use so I didn't think the larger line was needed. I appreciate your taking the time to answer though, I'm sure I'm not the first to come across these larger fittings and think I needed larger line.
Old 09-11-2009, 01:01 PM
w8ye
w8ye's Avatar
Very true
Old 09-11-2009, 07:11 PM
TravelairR
My Feedback: (7)
I've come across a new problem, the elevator connector is next to the receiver port for the electronic ignition port and I'm getting a lot of feedback to the servos. The ignition has an optic isolator that I thought would eliminate the jittering servos but it hasn't. The ignition is only affecting the elevator. I may have to pop for digital servos on the elevator. Either that or the electronic switch I bought isn't really an optic isolating unit. The feedback is speed related as the servos stay neutral until I take the RPM's up past half throttle, then it goes to full up. It's keeping me grounded while I break in the engine at least.
Harry
Old 09-11-2009, 07:49 PM
rhd-RCU
My Feedback: (36)
rhd-RCU's Avatar
since it is only one servo it could be a vibration problem. Try a different servo.
Old 09-11-2009, 10:41 PM
TravelairR
My Feedback: (7)
Nah, it's two servos on the elevator on one circuit, it is definately rf signals coming from the EI. I haven't hooked up the flap circuit yet and that is the connection on the other side of the pins so they may also be responding. I think it is only the circuit directly next to the EI connection.
Old 09-11-2009, 11:08 PM
rhd-RCU
My Feedback: (36)
rhd-RCU's Avatar
Why is your EI connected to the receiver?
Old 09-12-2009, 07:21 AM
TravelairR
My Feedback: (7)
EI is connected to receiver so that I have a radio controlled shut off. My transmitter, Spektrum DX-7, doesn't have a throttle cut button, so the only control I have in case of emergency is transmitter controlled shut off.
Harry
Old 09-12-2009, 04:23 PM
w8ye
w8ye's Avatar
Most people just pull the throttle trim all the way back to shut them off
Old 09-12-2009, 09:34 PM
TravelairR
My Feedback: (7)
Yes sir, that's one way to do it but if you have a servo fail or a linkage come disconnected a gasoline engine can fly a long time before it runs out of gas and it may not run out where you can easily get back to the field. It is much better to have a way to shut off the ignition someplace convenient. You know, it's like carrying a spare tire, you may never need it but if you do you don't want to not have it with you, it's the same thing with emergency shut off's, if you never need it fine, but if you do it may save your plane.
Harry
Old 09-12-2009, 10:21 PM
w8ye
w8ye's Avatar
Sometimes these extra nice to have goodies can be more trouble than they are worth.<div>
</div><div>It would be much better to have a gas tank that was only good for 20 min at most.</div>
Old 09-12-2009, 10:40 PM
TravelairR
My Feedback: (7)
That's one way to look at it. I may have to do without the switch but I think it is a worthwhile addition and will work at making it work. I'm sure not trying to tell everyone they need a switch like this, it's just something that has worked for me and I've witnessed enough incidents to know it has it's benefits. Thanks for your input though, it's better to hear others opinions than just be ignored.
Harry
Old 09-12-2009, 11:38 PM
w8ye
w8ye's Avatar
I know what you are talking about as far as run-away engines go. Been there and done that. Was at a lower throttle with no throttle control. The plane flew for 55 min before running out. It was the third flight on the batteries and I was afraid the flight batteries would give out but they didn't.
Old 09-13-2009, 03:55 PM
TravelairR
My Feedback: (7)
yep, I've seen planes wrecked just because of stuck throttles and no shut off, that's why I want to make this electronic switch work. If I never need it then I'm happy but if I do need it I'll be really happy I have it. Today I ran my ignition battery down to far and the engine quit but it is on my Rearwin Speedster and I floated her in for a safe landing.
Harry
Old 11-17-2009, 05:59 PM
Tiffoso
Tiffoso's Avatar
Hello, Gentleman. A friend of mine here in Brasil has one Fg 36 and he`s trying to figure out what is it`s working temp...does anyone has a clue about it??
Tks a lot.
Tiffoso
Old 11-17-2009, 06:16 PM
NM2K
My Feedback: (14)
ORIGINAL: TravelairR
Harry
Why not contact the optoisolator's designer, if they are still available? Sorry if you thought of this earlier.
Ed Cregger
Old 11-17-2009, 06:18 PM
NM2K
My Feedback: (14)
ORIGINAL: Tiffoso
Tks a lot.
Tiffoso
The only working temp that truly matters is an Exhaust Gas Temperature reading which requires a thermocouple sensing the exhaust stream. Those measuring IR radiation are pretty much useless.
Ed Cregger
Old 11-17-2009, 06:58 PM
w8ye
w8ye's Avatar
They do not seem to run that much hotter than a Saito 220.
