Dual Recievers????
My Feedback: (13)
RE: Dual Recievers????
This was popular a few years ago, but I think more current thinking is that one good receiver is OK. If you go this way, each receiver has its own battery and switch. Route the antennas apart from each other. Put the left aileron, left elevator and throttle on one receiver. Put the other stuff on the other receiver (rudder, right aileron, right elevator). The theory is that if one receiver fails, you can still land in one piece.
My thinking is that you double your chance of having some problem, but the problem is less severe. I prefer to put all my eggs in one basket...and guard the hell out of this basket.
My Feedback: (25)
AR
I go with:
#1: Left Ail, Right Ele, Throttle
#2: Right Ail, Left Ele, Rudder, Choke
I also put a jumper between the two RXs, pos and neg wires only, that has a 5-7 Amp fuse in it (mini auto fuse holder from RadioShack). It allows you to keep the whole plane should a battery or switch fail. Additionally, if something shorts or a servo binds, the fuse will blow and you will keep half the plane... you would lose the entire plane with the single RX setup. If you use a jumper and you are using LiIon w/ regs, the regs must be matched to within about .01V. You can easily do this with the Fromeco regs... they're adjustable.
Cheers and good luck.
NC
I use dual receivers in all my 40% planes. I use 2 switches and batteries. Just divide the plane in half, and run the right side on the right receiver, and the left side on the left receiver. You can criss cross if you want, but I keep it simple with just dividing the plane in half. Some people argue you only need one receiver, but I still use 2, and never had a problem, or any issue with reduced range. As a matter of fact, last week I was flying with a friend who used one receiver, and now he has switched to my set-up, and is using 2. It works great, and lessens the load on the receivers, lets more power get to the servo's, and provides redundancy. Use top quality batteries and switches, and I reccomend Fromeco products. Scott
My Feedback: (12)
NJ
My $8500 Yak would have been in garbage bags a few weeks back if I only had one receiver. I initially thought the problem was a bad matchbox but it turned out to be a bad receiver...this after 70+ flights. I lost half the elevator and almost did a figure nine! Not a warm and fuzzy feeling. Approach and landing was a none event with only one elevator working..although it obviously "felt" mushy. Use two...it's a no brainer.
Learpilot
Learpilot
ORIGINAL: Leardriver
My Feedback: (25)
AR
The antennae must be seperated as much as possible, preferably at 90 degree angles to each other, but ths is rarely practical. I general run one out the bottom of the plane and tape it to the bottom of the fuse, and I run the second up against the inside top of the turtle deck. Never had range issues this way.
My Feedback: (40)
IN
Dave,
The one thing you failed to mention and everyone else failed to ask is HOW BIG IS THIS PLANE?....
In my personal opinion, the H9 33% or any other 30% and smaller airplanes are perfectly fine on a single RX. Typically, I only use 2 RXs in 40% planes, but have used 2 in some 35%. It also depends on how you are setting it up. If you are using a higher number of servos, this can help split up the load on the RXs.
Again, my personal opinion, Redundancy is more important in batteries and switches than it is in RXs. MOST failures are batteries and switches. It is easy to connect to batteries to one RX and greatly reduce the chances of aircraft loss due to a bad switch or battery. This is how I set up my smaller planes.....33 to 35%
Hi david I have a 40% yak on dual receavers I use two bataries and two swiches the plane is split between them 1 servo from left Ail and one servo from right is in one
one servo from the ruder and one elevator is also in this one the balance is on the second
this way if one system fails the second will fly the airplane to safty
make sure you are useing PCM this way if You have a fialer it will not locck up the servos and the second will take controll
You can also split the throtle by puting a stack of two smaler servos and that way you are good for full controll
BC, CANADA
Hi everyone.
I have a question. Someone told me I can run two receivers and use a "Y" harness to each servo. Has anyone done this?
I have a Ziroli B25 that I am ready to put a receiver in, I was originally going to run one receiver with two batteries and two switches, now I am not so sure. At last count I will be running 11 servo's with some giant high torque servo's using lots of juice.
Last weekend I took out my something extra and have never had problems with it. Long story short, I had one small glitch in the air even after a good ground check, so I thought I should bring it in. On approach she started glitching like crazy and all control was lost, engine was even surging up and down. On crash examination everthing was working fine. Tore the nose of her though. I have since repaired it and have flown it several times, I had changed the switch but thats it.
So now I am real apprehensive about running one receiver on this bird. It does not have a split elevator, so if set up the way that is being discussed in this post, I would be screwed if the receiver that controls the elevator craps out.
Any suggestions?
Thanks[img][/img] Peter
Any suggestions?
My Feedback: (25)
AR
My Feedback: (12)
NJ
ORIGINAL: aresti2004
How did you determine this? Did the RX die completely? What was the failure mode??
I initially could not reproduce the problem at all. After I landed I killed the engine and walked out to get the plane. It was very obvious one of the elevators was not working..it just sat there with no power/signal to it......I was able to move it like the power was turned off. As I'm dragging the thing back to pit area all of a sudden the elevator "sprang" back to life and we could not get it to fail again no matter what we did. The general consensus was matchbox because that seemed like the most likely point of failure (yes all the connections were checked). I had Smart-Fly equalizers in the stabs so when I got home I made up 2 new extensions and ripped out the matchboxes from the plane. Since I had two unused channels available I simple mixed all four servos using the Elevator as a master. After I finished matching and mixing everything I was sitting behind the plane double checking things when "Whamo" the damn thing failed right in front of me AGAIN. And just as mysteriously it started working again and I could not get it to fail on cue! It was like there was a damn Gremlin in my plane! I decided to get another receiver to have handy to start swapping things out. I left the radio on and when I came back everything on the right receiver had failed! This was new....previously it had only been the elevator half plugged into that particular receiver. I swapped out the receiver and everything worked fine ....swapped back to the original rx and it was intermittent at best. I than swapped out the crystal with no better result. Next I plugged everything into the "other" receiver in the plane (the left one) and everything worked perfectly. One final swap back to the right rx had the same results as before. It was definitely the receiver. There was approx 75 flights on the plane when this happened by the way.
Here is the crazy thing. 20 flights later (with a brand new receiver on the right) the left receiver up and died at Joe Nall this year!! It is freaky that that would happen. These two receivers were in a crash (a deadstick landing that didn't make the runway) but went back to Radio South for "inspection". They came back with a clean bill of health (the crystals were replaced as a precaution)..plus a $50 bill! Anyway...another new receiver has been installed and another 20 or so uneventful flights have been put on the plane. OH yes......both rx are wrapped in foam to isolate as much vibration as possible
I was really beginning to suspect the voltage regulators on the powerbox but I have checked it and it is exactly 5.9 volts as advertised so it appears as though it is just a very strange coincidence....time will tell. I have not sent the bad rceivers back yet but I will prob this coming week. The bottom line here is that this plane has been landed TWICE with one rx working and one not. It is not a switch or a bad battery either....it was a bad rx both times! I simply can't see running only rx because not only would I have destroyed one giant scale plane....guess where the other rx would have been....in my brand new Super Xtra! Yup......about $14,000 worth of little pieces of composite confetti would have been my reward for a single receiver setup.
leardriver
