Carden Aircraft Post threads here related to the Carden Aircraft line
tail gear... need advice..
Old 01-02-2007, 05:50 PM
Xtra260
Default tail gear... need advice..
Hi everyone..
I am building carden aircraft 40% Extra 260. what's the recommend to have tail gear for it? I am not sure if I heard right something about kwett hobby? i was told it's great tail gear... ain't sure if i spelled right... help?
Ken
Old 01-02-2007, 06:09 PM
ballistic1
My Feedback: (27)
Default RE: tail gear... need advice..
dont know why the picture dident come out?
ID:	589109   Click image for larger version
ID:	589113   Click image for larger version
ID:	589114   Click image for larger version
ID:	589115   Click image for larger version
Old 01-02-2007, 08:38 PM
Flyin Woodbutcher
which wheel did you get. The Petes work great, tire stays on the hub. The other tail gear that has a bracket on only one side will not retain the tire. A hard turn or a bonch and slide and the tire will outrun the plane.
Kent
Old 01-03-2007, 04:40 PM
as722
I used the titanium wheel from rc blimp and while it's the strongest wheel I've ever seen and also very well made it has very little clearance between the bottom of the carbon "caster" and the ground and it always digs into the grass so with that said if I flew from black top or at triple tree I would use the titanium wheel otherwise I like the Pete's carbon wheel better but it's not made as well.
Albert
