still having body roll problems sank it 4 times PLEASE MORE HELP
Old 03-25-2008, 07:39 PM
jwblocal701
Default still having body roll problems sank it 4 times PLEASE MORE HELP
Well tried a diffrent prop recomended from Bonzi sports no help. If i give it gas it wants to turn over on its side. it rolls to the left(exhaust)bad ealy bad it turns itself over if i let it. Should the front of the boat have weight in it? I am totally lost and have no IDEA what to do
here are some pictures of my setup if someone can help
Old 03-25-2008, 08:13 PM
jwblocal701
Default RE: still having body roll problems sank it 4 times PLEASE MORE HELP
could it be to light in the fron since it is hollow up in the fron
Old 03-25-2008, 08:23 PM
jwblocal701
front i mean
Old 03-25-2008, 08:32 PM
glennb2006
ORIGINAL: jwblocal701
Picture three and six should give you a clue where your problem lies. Probably...
G
Old 03-25-2008, 08:33 PM
jwblocal701
ok what ??? tell me what u see thats what im asking
Old 03-25-2008, 08:45 PM
mike the snake
I just helped a guy get his boat running pretty well last weekend, it was a big Bonzi with QD35. At a certain speed it would buck out of the water or spin out.
We angled the prop down and it totally helped. Also we set the trim tabs to counter the torque effect (left level, right down a bit).
Your strut or stinger looks to be angled up a bit. Try 3 or 4 degrees down, it was like night and day on the boat we were tuning
Old 03-25-2008, 08:49 PM
jwblocal701
the strut is all the way up but the rudders move as well. I have moved the prope up down and as well as the trim tabs.. Moving the trim tabs made it a little better but it also handles like crap.. How is it a Proboat shockwave 55 ss is better out of the box than building your own out of better parts. I cant figure that out...
is it normal for rc boats to have roll to them... I Had this same motor in a 43" Aeromarine deep v hull with no problems at all boat went straight as an arrow
Old 03-25-2008, 08:50 PM
jwblocal701
sould there be weight in the bow of the boat or just hollow???
Old 03-25-2008, 08:57 PM
glennb2006
The boat should, as all boats should be, as light as is possible.
So no ballast in the front end.
Glenn
Old 03-25-2008, 10:24 PM
stuch
call Tony at whh he'll tell you how to correct it 863-699-1231
Old 03-25-2008, 11:17 PM
Jager 247
Jager 247's Avatar
wow stuch are you being paid for every time you mention whh in a post?
Old 03-26-2008, 04:12 AM
stuch
ORIGINAL: Jager 247
is this you're week to watch my posts? no but his boat is mostly whh and nobody can seem to help this guy. this is his 2nd thread on the same problem. i just know that Tony,
the guy that invented gasoline model boating knows alot about this subject. and every time i ever had a problem that nobody could help me with Tony solved. now if his boat didn't have anything to do with whh why would i say call whh? seems like you can't give the guy good info so why even waste you're time posting on the thread about me and whh.
Old 03-26-2008, 05:59 AM
mannymach1
I would try to move the trim tabs out to the edge of the boat.
Old 03-26-2008, 06:06 AM
pyro1
Stuch,
Fyi, Tony did not invent model gas boating. If you know Tony he will tell you that. I do believe he can help in this issue. I do know Tony well and he is an honest straight shooter when it comes to his passion ( model boating). I truly believe that Whobbies has the best customer service in the industry. ( just my opinion )
keep the hobby alive![sm=49_49.gif]
Pyro 1
Old 03-26-2008, 06:21 AM
wayneuk01
If the boat keeps rolling left add some weight to the right to balance it
Old 03-26-2008, 07:59 AM
mopartybob
first thing i notice is your prop is angled a bit too high.......and you've got waaay too much trim tabs IN the water.....[:-],especially the starboard (rightside),all this along with a bad CenterOfGravity,will produce results as you've mentioned....if it was due to too much prop....it would roll to the right,right???,right. Lower your strut to at least 1-2*neg (down) angle,raise your tabs so they are at least 4*pos.,and this will give you a baseline to start with,Keeping in mind that if any part of a trim tab is mounted flush,or below the hull,this will induce drag making fine tuning a biotch to do....if the problem is worse,lower the tab on the side it rolls to (left???),if you have to go more than 4* down,then look to shifting/adding weight to the right side....not always a bad thing,but what else you gonna do???/....try it out first by accelerating slowly and see if that helps....good luck...
Old 03-26-2008, 08:21 AM
Ron Olson
Ron Olson's Avatar
No, Tony didn't invent model gas boating. They're been around since before he was filling diapers. Ever hear of O&R engines? They're just one example of vintage gas engines.
Back to the thread at hand. The prop appears to be rather dull. Has it been sharpened and balanced? Is the hull flat with no hooks in it that can be affecting the handling?
One more drastic thing could be that you'd need to move the strut to the right to help compensate for torque.
Old 03-26-2008, 09:10 AM
jwblocal701
Yes the prop is sharp and balanced thats a old one i installed a new one just not pictured here
the hull is perfectly smooth underneath
I spoke to tony at WHH gave me some good ideas. I think is just comes down to poor hull design
Its a Plum Krazy RC boat hull
Old 03-26-2008, 09:13 AM
martno1fan
martno1fan's Avatar
I think Glenn irs refering to the mounting of the hardware it looks slanted? doesnt look like its mounted square to the transome?
Old 03-26-2008, 09:23 AM
mopartybob
it's one of vern's hulls mart..... jwb,it would'nt happen to be a 45" cobra max gt hull would it????[:@]if so,take a read http://www.rcuniverse.com/forum/m_65...tm.htm#6590809
Old 03-26-2008, 09:40 AM
jwblocal701
its the 51 inch one not th 48
Old 03-26-2008, 09:42 AM
jwblocal701
it would be the black shark on http://www.bluefishy78.com/page12.html
Old 03-26-2008, 09:57 AM
wayneuk01
got more hook than Abu Hamza
Old 03-26-2008, 10:03 AM
jwblocal701
so now what 2 more trim tabs on each side?? sell the hull and start over? i dont race it i just play in my backyard but i want it to go straight atleast
what is hook???? its not turning the darn thing wants to flip onto its side it actually goes straight if im using it if i give it to much gase the whole thing is rolling over on its side like telling a dog "ROLL OVER BOY"
Old 03-26-2008, 10:38 AM
brodjack
My pals boat,the Spiderman,looks similar rudder gear etc.
His pulls badly to the right.
Reckons he'll sort it with trimming and prop angles.
Perhaps its a two rudder thing? i've no idea myself though...
Brod..
