Props for chainsaw engine
Old 03-31-2008, 04:44 PM
itswatido
Default Props for chainsaw engine
If I want to use a poulan chainsaw engine for a boat, are there not any props that are available that rotate in the correct direction. Iv been told that they turn the "wrong way".
Old 03-31-2008, 06:18 PM
Justaddwata
Justaddwata's Avatar
Default RE: Props for chainsaw engine
There are plenty of props that are counter rotating. Propshop make most sizes in a counter rotating match. Voodoo props also have a few on offer.
You will also need to buy a counter rotating flex cable as a standard cable will fail in seconds spinning the wrong direction.
Old 03-31-2008, 07:03 PM
itswatido
thanks alot.. all this advice is definately gunna help in the build
Old 03-31-2008, 09:56 PM
nofords
nofords's Avatar
Put a flex collet on the recoil shaft and put a starter pulley on the clutch shaft. Then you can buy a std rotation prop.
you can also modify a recoil system to start the chainsaw on the clutch shaft. or do one of each and make a boat with twins!
Old 04-01-2008, 04:08 PM
itswatido
i was considering twins... but im not sure if the boat im buildig will handle it. Its only a 48". Its prolly wide enough but with the added weight of twins, im not sure if tll be ok.
