how to shut of boat!
ON, CANADA
Well i bought a team pro a while back and have been really busy to get it started but im going to break it in tomorrow morning...
But what is the best way to shut it off???
I have nitro cars and i just plug the pipe, will that work???
RE: how to shut of boat!
Read this thread, it may give you some ideas. You basically want to be able to shut the carb via your radio.
[link=http://www.rcuniverse.com/forum/m_8908751/tm.htm]http://www.rcuniverse.com/forum/m_8908751/tm.htm[/link]
PA
you can turn the choke on also that will stall the engine.
I don't like to do that.
I have a fail safe on my radio so all I did was throw a screw through the metal back plate that the pull starter is bolted to.
Take the black wire from the coil and touch it to the screw and that shuts it down.
I did that so I could leave the boot around the black wire and it fits over the screw just right.
The other option is the EKG from WHH or the PB kill switch.
www.rckillswitch.com
