Pizazz -Receiver antenna routeing????
In in the final stages on the Pizazz. About ready to go. One thing, The manual says run the antenna out through the bottom of the hatch. I dont really like that idea. Everytime you remove the hatch your going to have to monkey with the antenna and could damage it. So, how did you guys run the antenna in your Pizazz. Got any ideas? Or should I just go with the instructions. Thanks, JT
IN
JT i have built 2 pizazz's and i always did them the way the book said. I used clear 3m tape and taped it to the botom of the fuselage all the way back. Once you get the plane setup, you shouldn't really have to take the hatch off to do anything. Thats the way i did them and haven't had any trouble so far. Hope this helps. Robin
run it back to behind the rear of the hatch in some tubing glued to the sides, then exit behind the hatch on the bottom. Cut the tubing into short sections, all you want to do is keep it out of the servo.
Ed M.
Ed M.
