simulated "disaster"
Many times as i sit through my classes i come up with some amazing ideas. my newest ide being some "bullet holes" in the fuse with piping connected to a smoke system. another great idea was a hinged pilot that could eject with a parachute . the servo would slide the canopy open while pulling a pin on the pilot. a ring in the piluts butt would slide into a slotted seat. a push rod could run through the ring to hold the pilot down. when the canopy servo rod slides back the same rod could unlock the pilot. i was thinking something alogn the lines of spring loading the pilot. of course its not the most defined plan but with some time and testing i think it could be impressive. im into making some scale destruction so to spak. feel free to share ideas.
RE: simulated "disaster"
yeah i payed for the classes.. ha. i was just hoping for some inventinve ideas like my own. but i guess being the inventinve one i am i should expect criticizm. and actually i hadnt planned on crashing the plane. although it would look good with some pyrotechnics J/k.. the mock dogfight could end after the plane "caught fire". and i still hope to recive some good comments on ideas. but i never turn down criticizm.
Being that they are WARbirds. i figured reenacting what they do best was a decent plan. Id have to say the things they did best was shoot and get shot. Any plane can fly and fly well. thats a given. thats what makes these warbirds different. they were used for waring. so i find smoking fuses and vacating pilots a good thought. ha oh well i was hoping for more enthusiam
MI
Hi, No disrespect intended, Just struck a nerve, my oldest son graduating this year and looking at college next year, and i got a mental, him just sitting there day dreaming on my dime,....sorry,.........anyway, it's all i can do just to keep a plane in the air let alone dogfighting, not a bad idea,...be kinda neat,.......Paul
ha i knew someone would say i cant spell.. i think id call it dyslexic typing. but oh well. and its ok i can understand daydreaming being an issue. but thats an entirely different thread. ive had issues concentrating since 2nd grade. i have a good imagination is all really. and if anyone else does speak up.
My Feedback: (8)
It's all tongue-in-cheek.
Anyway, to focus on your original post, the "ejection" mechanism would have to produce a fairly significant force to overcome any Gz on the plane and to clear the pilot vertically from the prop. The model would also have a sudden cg change (unless the pilot was directly over or very near the cg) and increased drag with the canopy gone. These aren't insurmountable mechanical problems, but I question if the end result would be worth the effort.
yes these are all things to be considered. i do agree it wouldnt be a simple thing. but of course id never do this with a scale plane. a sport scale would do the trick because CG is less meaningful and the planes fly alot easier. haha now to thikn id do this foolish stuff on a really scale plane .. then i woudl expect you guys to think im nuts. but still i am going to tinker with the idea more.
My Feedback: (25)
Byron Originals used to put on a show called "Striking Back", I think you would like this. He even had flack guns! Planes were rigged with small explosive charges, just all kinds of cool stuff. A pilot eject would not be to hard to do, once the canopy was open and he wasn't strapped in he would probably be sucked out! A small spring with a 1/16" ply plate on top for the seat bottom, hooked to a servo would work, once just a small part of him was in the slip stream I'm positive he would be sucked out. They do have R/C skydivers, just make a military one with a simple round parachute that will open with one small servo. CG would not be a factor, just check the CG with the pilot in place, when he "ejects" the plane will be slightly nose heavy, big deal!
Luke
Luke
you are my savior. finally some slight proof im not the only one with inventive ideas... man thats an amazing thing to hear.
