Xl disaster
Xl disaster
I had just got my brand new 5.9 engine i got on warranty run in and was tryin some full power runs and the central gearbox detonated so took it apart and found there was no grease on any of the gears, is this supposed to be like this?
RE: Xl disaster
Yea it stripped 1st, 2 and 3 in behind the spur gear there is just nothing left 3rd on the next shaft is missing a few teeth and it broke the pin that holds the clutch on 2nd it has fairly wrecked itself!
KS
RE: Xl disaster
Usually the disaster starts with the final drive gear. It breaks and the parts wipe out the rest. The 3 speed is not nearly as robust as the newer two speeds, but it should hold your 5.9 for several gallons....like around 7 or 8 normally. Glen
RE: Xl disaster
Yea my gearbox looks like that lol but the final drive was the only row of gears that wasnt missing teeth, priced up sorting it all the bits are costing less than £30 gb inc delivery which i thought wasnt bad at all i was expecting a lot more. But gears with no lube i have never seen that before
