thottle rubber cover
Old 09-20-2006, 12:25 PM
Splinterwelsh
Default thottle rubber cover
Hi all, when I go full throttle, the throttle rubber cover stretches then when let go of the trigger the car is still throttling for two seconds because the rubber cover is not folding back in right.
Any ideas why this is happening?
Thanks all.
Old 09-20-2006, 01:44 PM
muddymoose92
muddymoose92's Avatar
Default RE: thottle rubber cover
Wear and tear
Old 09-20-2006, 02:15 PM
Splinterwelsh
The car is brand new, there no tears and it looks perfect. But the throttle arm dont close straight away when i let go of the trigger, it sorta sticks but I put a little drop of oil just incase it sticks. But it still the same.
I really need help on this
Old 09-20-2006, 02:22 PM
snowbl!nd
snowbl!nd's Avatar
Make sure the rubber dirt shield is where it should be - there are usually grooves to locate it. If it's jumped out of where it should be it could get jammed and stop the carb closing properly.
Old 09-20-2006, 03:44 PM
Splinterwelsh
Have you got msn, aim or yahoo? I really need help on this[]
Old 09-20-2006, 05:15 PM
snowbl!nd
snowbl!nd's Avatar
A few photos might help
Old 09-20-2006, 06:21 PM
ASSOCIATED_DRIVER
ASSOCIATED_DRIVER's Avatar
Do you have a throttle return spring installed?
Old 09-20-2006, 07:34 PM
Splinterwelsh
Yes, I have a throttle return spring
Old 09-20-2006, 08:55 PM
hands without shadows
hands without shadows's Avatar
Is it your servo or the actual mechanism?
Old 09-21-2006, 09:15 AM
Philster
You servo has to be dogmeat. Any decent servo should shut that sucker clean, spring or no spring.
Old 09-21-2006, 11:31 AM
Splinterwelsh
heres a video of it
http://www.youtube.com/watch?v=iPWro8od2KM
Old 09-21-2006, 02:11 PM
Splinterwelsh
Another video, sound isnt very good but...
http://www.youtube.com/watch?v=sXh6Lo5nfBM
Old 09-21-2006, 03:26 PM
Splinterwelsh
Do you think it could be anything to do with the low speed needle rear??
Old 09-21-2006, 03:38 PM
ASSOCIATED_DRIVER
From the first video, it looks like air is slowly escaping out of the accordion looking cover, also it looks like plastic not rubber, try to put a small hole on it, so the air doesnt get trapped inside.
Old 09-21-2006, 03:40 PM
ASSOCIATED_DRIVER
Also notice the same thing from going full throttle, air is also slowly getting sucked in the cover, that's why you have a delay on your throttle response.
Old 09-22-2006, 07:56 AM
Splinterwelsh
Got that sorted Thanks. But my hyper 7 is crap at the mo just can't seem to get it right now its cutting out i put it all back to fact high and low speed settings and started to tune it but its hard to start and when it do pull on the throttle a little and it will just stop running same as if i get it up to just off full throttle its will just stop running there is a lot of smoke coming out of the exhaust to and thats after i tryed to tuned it to PLEASE!!!!!! HELP!!!!!!!
Old 09-22-2006, 08:04 AM
snowbl!nd
snowbl!nd's Avatar
Lot's of smoke = too rich. Try leaning the LSN.
Old 09-22-2006, 02:12 PM
Splinterwelsh
Got it pretty much up and running
When to the local road and had a race with a bike, a few cars and even a bus lol. I could of beat them easily it was so fast, awesome car. Really fast lol
