TWIN ARF
My Feedback: (18)
RE: TWIN ARF
Heyy GremlinX,,
The Seagul twin is as close as you will get to a twin Comanche
in a .40 size right now.. if you go into the .60/.90size KMP has
the 336 .. Most everything else in multi's are warbirds which
there are quite a few from different sources..
In kits there is a twin Comanche from Jack Stafford Models..
You might find one of the older twin Beach or Royal/Martuka
310 models at a swap like Perry this coming week end. They
are about the same size as the V35 you currently have and
use .40/.50 motors...
AB, CANADA
RE: TWIN ARF
http://www.hobbypeople.net/gallery/190101.asp
our LHS just got one in,..fg fuse...looks really really nice
Using a combination of a strong, lightweight moulded plastic ‘shell’ over a carbon reinforced balsa and ply internal structure, the complex curves of the DH88 Comet are faithfully reproduced in this semi-scale almost ready to fly model. The tail surfaces and wing use a traditional built up structure that has been factory built and covered in film with the simple white insignia and trim already applied with pre-painted moulded engine nacelles requiring only the minimum of installation work.
Designed for a pair of .52 size four strokes (Magnum FS52 recommended) or go electric with a pair of brushless motors - mounts are included for both options. Designed for retracts, a custom set of air operated retracts are available -Click on the Items Needed Link.
The Comet is designed for aileron, elevator, rudder, throttle, retracts and flap control using a combination of standard and micro servos. For strength, the outboard wing panels plug in to the center section using aluminium tube joiners but the wing is removable for easy transport.
