OMP - Ohio Model Products Support Forum Discuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
Glue for Balsa to Foam??
Old 10-08-2004, 08:56 PM
Sewerdude
My Feedback: (20)
Sewerdude's Avatar
Default Glue for Balsa to Foam??
Whats the best glue to use to glue the balsa sheeting onto the foam fuse. I just got a 47" Edge. Does any glue work other than the Gorilla glue? Was wondering if something Titebond would work. I've heard horror stories about usin the poly and the sheeting sliding off the foam if you dont use enough weight. Thanks, JT
Old 10-09-2004, 05:54 AM
STLPilot
My Feedback: (21)
Default RE: Glue for Balsa to Foam??
Hopefully well get some good answers from everyone, when we do we'll make this thread a sticky for the forum. We get asked this a lot.
Old 10-09-2004, 07:17 PM
remcl1
remcl1's Avatar
I used Gorilla Glue on both the GS Edge 540 and the Yak 65 with no problems. I did not use lots of weight. With the two planes I used a sheet of 3/4" plywood to spread out the weight and put two car batteries on it. The Gorilla Glue really does work well and you do not have to be afraid of it. I would hate you see you shy away from it and compromise because you have a miss conception that you have to place a mac truck over it in order to get it to work. I suspect if the sheeting actually slid off then way too much glue was used. Any product will be a headache if not used right.
Old 10-09-2004, 07:19 PM
remcl1
remcl1's Avatar
STL,
You missed your mark. Orlando is not is PA. What happened, the hurricanes scare you away?
Old 10-10-2004, 08:27 PM
RJConnet
I used 30 minute epoxy thinned with alcohol. Edge glued the sheeting, painted the epoxy on the foam, layed it on the sheeting covered it with a flat board on a flat surface and weighed it down with a tool box full of automotive tools (about 40 pounds) and let it cure. Then painted the other side of the foam and repeated the above. Came out straight as an arrow and is hanging together real well............RJ
Old 10-12-2004, 08:04 AM
AFSalmon
AFSalmon's Avatar
This thread is also running in the main fun fly forum. I'd recommend removing it here as it's not necessarily OMP specific.
Old 10-16-2004, 04:36 AM
aeroastro
West Systems 206/105, vacuum bagged, works well. I also laid in some c/f mat at critical stress
points (TE junction) under the balsa.
Peter Young
Watertown MA
Old 12-02-2004, 09:23 AM
midi0101
Hi there,
I use just white wood clue......is almost as strong as epoxy, but much lighter
Michael
Old 12-03-2004, 08:45 AM
AFSalmon
AFSalmon's Avatar
Gorilla glue without hesitation is the preferred method by all OMP folks. This stuff penetrates the wood and foam better than any other glue. We use it on all balsa to foam from the profiles to giant scale planes. Plus it is non-toxic!
By the way we keep plenty of Gorilla glue in stock in various size bottles so if anyone ever needs some with their kit, just say so.
Old 01-16-2005, 05:32 PM
solarviper
My Feedback: (139)
i just built a Giles 202 with foam core wings, i used 100% polyurethane glue, it has unbelievable holding power, and can be bought at home depot or Lowe's..this is also what some manufactures have told me to use
Old 02-16-2005, 09:54 PM
Jon B
I have a 47" edge that I'm getting ready to start on. I want to use polyurethane glue on the fuse like the instructions say, but I don't have any experience using it. How much should I use so that the balsa sheeting doesn't slide off? The instructions say to use 200 lbs. of weight hold the sheeting in place. Is that realy necessary?
Thanks!
Old 02-16-2005, 10:46 PM
Woody218
My Feedback: (24)
Woody218's Avatar
You want a LIGHT film of glue, because as it cures, the poly glues expand in volume, this is why you need enough weight to hold it all together. I squeeze out some glue, and use an old playing card to spread the glue across the foam core. You can drill a couple small holes in the sheeting and insert round toothpicks through the holes into the core to prevent it from sliding off the core.
Cut the toothpicks flush with the sheeting before you add the weight.
This stuff isn't as scary as you may have read, but if you're in doubt, find an old piece of foam and a scrap piece of sheeting, and make a test run with it so you're comfortable with the procedure before you do the real thing.
Old 02-17-2005, 11:55 AM
Jon B
What about the weight needed to hold the sheeting in place. remcl1 uses two car batteries but the instructions say 200 lbs would be adequate. I would think 200 lbs might deform the foam core.
Old 02-17-2005, 12:22 PM
Woody218
My Feedback: (24)
Woody218's Avatar
You want the weight spread out over the entire surface of the core. When I built my 65" Yak fuse, I used a piece of granite trim off a building, it's 48" long, 20" wide, and it probably weighs close to 300 pounds, but if you think about it, that much weight spread over 200 square inches is only 1.5 pounds/sq. in. That's not anywhere close to the compression load of blue foam. I have made 72" foam core wings with plain old white styrofoam, and used almost 800 pounds of weight on them while the glue cured. The Gorilla glue actually came up through the balsa sheeting, and it forces itself so deep into the foam core you can't believe it!
You need lotsa weight!!
Old 02-17-2005, 01:21 PM
Jon B
Thanks for your input. I'll find some scrap pieces and give it a try.
Jon B.
Old 02-25-2005, 09:13 AM
J. Fouty
The poly glues react to water. If it is cold and dry it will take longer to cure and won't expand as much. A very light mist from a spray bottle on the cores will really set the glue off.
Jeff
Old 02-25-2005, 02:05 PM
rkrider
How would this work ?
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXB967&P=7]Dave Brown Southern's Sorghum [/link]
Old 02-25-2005, 11:34 PM
J. Fouty
I used it a long time ago on some wing cores. It works pretty well for wing skins, but I'm not sure how well it would adhere the balsa skin to the hard points like the lg mounts or motor mounts. It is really easy to use, and actually smells good. It is a kind of latex sugar and water based contact cement, that brushes on like paint.
Old 02-28-2005, 10:10 PM
jlmeyers
I used 3M spray contact cement on my 80" edge, Yak54 and my small Edge and it holds great. Spray both sides with adhesive and allow it to dry then stick them together. Viola, instant bond. It is important tp allow the glue to dry first though, If you do not the cement will attack the foam.
Old 03-05-2005, 11:39 AM
westy1957
westy1957's Avatar
Hello, I write from Italy, and I don't know the Gorilla glue, neither I can buy it......
I ask: is it an Aliphatic Resin Glue ?
Can I use Great Planes Aliphatic Resin Glue to Glue Balsa to Foam?
Thankyou
Ciao
Old 03-07-2005, 01:35 PM
AFSalmon
AFSalmon's Avatar
No, Gorilla glue and ProBond brands are polyurethane glues and expand into the pores of the wood and foam when curing. This is what provides the superior bonding. Yes you can use aliphatic glues but I would still weight the cores down to be sure you get as tight a bond between the balsa and foam as possible. Thinned epoxy also works well but with all the above choices just be sure not to use too much.
Old 04-05-2005, 09:23 PM
gerryw
Use 2 Gal ziplocks filled with sand for weights works great.
Old 04-14-2005, 02:05 PM
geebob@brownsphoto
Hey guys, I'm no expert by far but I did run into a small problem with the Gorilla glue on my "80 edge kit. I got some of the glue in the wire channel and it blocked the channel. If I were to do it again (I'll buy the arf LOL ) but I would put a strip of masking tape over the wire channel before I glued the skins to the cores.
Just one mans opinion I could be wrong
Old 04-15-2005, 07:54 AM
AFSalmon
AFSalmon's Avatar
Hey that's actually a good idea. Thanks for the tip. Also keep in mind these modern urethane glues are really strong and you don't need very much at all. All you need is a very thin layer, wet the apposing side, and make your sandwich. The water helps activate the glue and allows better expansion into the pores. If you use too much glue it will expand into the servo channels.
Old 04-23-2005, 07:46 AM
Dragondawn
Dragondawn's Avatar
FWIW, I tried a foaming/expanding polyurethane glue on a balsa/depron fus... unfortunately I didn't spread it out well enough and where it was thickest in the middle of the fus it expanded BIG time! I had sheets of 3/8" glass on top and then 1/2 doz house bricks for weight. When I made the cut-out for the wing I found gaps of ~1/16" where the glue had 'bubbled' [] Strike One! On my second attempt I used a very thin skim of 30min epoxy
I'm not saying don't use PU glue, just make sure it's a real thin, even layer you're putting on.
(BTW the poly glue I got here in the U.K. is like the thickness & consistancy of silicon sealer and it comes in the same type of industrial tube. If Gorilla is thinner then you'll have an easier time).
HTH,
Steve
