Your Electric Heli model & Components here.......
RE: Your Electric Heli model & Components here.......
Feda Dragonfly - GWS ICS100, ICS50 ESCs, GWS RX, PG03 Gyro, 300 Main motor, DD Tail Motor, 2 cell 1200 Lipo.
Airwolf Hummingbird - GWS ICS100, ICS50 ESCs, GWS RX, CSM HLG200, Stock motor, DD Tail, 2 cell 1200 Lipo.
Hitec Eclipse 7 TX.
Steve.
Hitec Eclipse 7 TX.
Steve.
-=Gws Mini dragonfly=-
futaba 4ch t4vf radio
gws 6ch naro Rx
gws mixer/esc
gws pg03 gyro
stock everything.
2x 750ma batt backs (approx 6 minutes)
gws em150 stock motor(270 sized can)
I modified my tail rotor with a mod'd cox 7" LH prop. Used fuel tubing instead of meta colar to replace the "black" silicon tube on mainshaft. modified outer control plate(increased strength of ball link).
still experimenting... :-)
gws 6ch naro Rx
gws mixer/esc
gws pg03 gyro
stock everything.
WI
Century HB
stock motors
GWS ICS 300 & ICS 100 ESC's
GWS rx
GWS Naro BB servo's
Futaba GY240 Gyro
Futaba 9C tx
Thunder Power 3 cell 860 or 1320 mAH pack
Regards,
Mike
stock motors
GWS rx
GWS Naro BB servo's
Futaba GY240 Gyro
Futaba 9C tx
Regards,
Mike
HB with stock setup, Futaba Super 7 radio, head stiffener. Airwolf HB stock setup w same radio and head stiffener (currently being built up and most likely going to upgrade to the Hornet CP.
=Jabo Dragonfly=
- GWS Pha-01 3in1 board.
- GWS 4P-H Rx.
- Hitec Flash 5 Tx.
- edp50xc DD tail motor.
- Head stiffener.
- swashplate with ball.
- Shaft collar.
- Stock main motor, soon to be swapped with Johnson250.
Best regards.
- GWS 4P-H Rx.
- Hitec Flash 5 Tx.
- Head stiffener.
- Shaft collar.
Best regards.
Mine:
GWS Dragonfly
GWS 6 Channel RX
ESC Mixer (GWS build?)
PG-03 Gyro
GWS GWT-4A (Original Mode 1 but modified to Mode 2)
EM300 (Mabuchi RK-370SD http://www.mabuchi-motor.co.jp/cgi-b...AT_ID=rk_370sd)
10 Teeth plastic pinion.
EDF50B (CN12-RLC Motor) with 5 blades fan tail.
DIY EDF Tail bracket.
DIY Aluminium Head Stiffener
DIY Two-In-One Battery Compartment.
DIY Rubber Duck Antenna
Soon to be DIY Shaft Collar (My stock rubber tubing wear out already)
7 Cells NiMH 750mAH
2 Cells Li-Polymer 1500mAH Kokam (SLB 603870H http://www.kokam.com/english/product/battery02.html#03)
Super-Hornet
GWS Dragonfly
GWS 6 Channel RX
PG-03 Gyro
7 Cells NiMH 750mAH
Super-Hornet
I have fully modified my dragonfly(hb)
New carbon frame, new carbon boom(shorter)
JR 378 With Hitec feather reciever 9grams and 2 hs 50 servos
wattage 370 motor
2 cell lithium-pol kokam 1500 (20minutes+)
Mixer/speedcontroll unit
Piezo gyro- very small
Direct Drive tail motor with 3*2 prop
cut down blades with balsa filling the undercamber bit (so that it turns out to be semi symetrical)
Home made ball in swash
Shaft collar
Head stifener(carbon)
Flies great even in a bit of wind
Phil
wattage 370 motor
Shaft collar
Phil
MI
aerohawk
johnson 250 motor upgrade
holes in blades upgrade
trimed blades 3mm to 2mm to root
adjusted gyro gain and tail speed for new motor
balanced blades and rotor head
lipo batt 2 cell 1200mah
shaft collar
shaft collar
Feda Dragonfly (originally)
[ul][*] DIY FRP subframe[*] DIY landing gear[*] DIY tail fins (FRP)[*] DIY tail motor mount (DD tail)[*] DIY tail support[*] DIY canopy (baby shampoo bottle)[*] DIY adjustable (control) pushrods[*] DIY anti-rotation arms (inner and outer swash)[*] cut down Aerohawk blades (5mm-root, 3mm-tip) [*] alu swash[*] alu shaft collar[*] dual head stiffiner[*] titanium (bike spoke) flybar, paddles modified as well[*] GY240[*] GWS pico servos[*] ICS50 for DD tail[*] P-10 for Astro 10t (11t pinion)[*] 2S ETEC lipoly[*] GWS pico receiver[*] 9CHP
[/ul]
[/ul]
My Aero hawk don´t fly more 3 foot, I already change teh battery (7.4v 1400MA)
Do you know what hapend
ORIGINAL: rodgermoore2001
aerohawk
aerohawk
ORIGINAL: avance_x
[/ul]
[/ul]
HB
Stock Motor
DD tail
Cupid Swash (with ball)
Waypoint 60 servos
Berg 5 rec
Airwolf HB
Himax 2015 4100 motor
CC p10 esc
Trec tail esc
Stock tail motor
Century Servos
GY240 gyro
Berg 4 rec
TP 1320 3s lipo
Hornet 2
Razor MH V2
CC P10 esc
HS 50s
HS 55 tail
Swash with ball
GY 401
still working on it
Corona
Hacker C40 12
Hacker 40-3 esc
HS 81 MGs
Crazy Crutch
Dave Belt Drive
Matts Tail Belt Drive
CSM 200 L gyro
Stock Motor
DD tail
Waypoint 60 servos
Berg 5 rec
Airwolf HB
CC p10 esc
Trec tail esc
Stock tail motor
Century Servos
GY240 gyro
Berg 4 rec
TP 1320 3s lipo
Hornet 2
Razor MH V2
CC P10 esc
HS 50s
HS 55 tail
Swash with ball
GY 401
still working on it
Corona
Hacker C40 12
Hacker 40-3 esc
HS 81 MGs
Crazy Crutch
Dave Belt Drive
CSM 200 L gyro
Stock Aerohawk with DIY mods:
- holes in blades, flybar paddles, tail rotor: reduced head weight, increased lift and reduced blade drag
- cutdown/trimdown: 5% blades/flybar paddles
10% tail rotor
8% tail boom
- rubber springs in head to keep blades in advanced position
- weightless shaft collar
- weightless rubber bands battery mount
- Improved canopy structure, 40% canopy weight reduction
- removed other small parts, body weight reduction 2%
- slant tail fin to improve heading stability
Flight time record: 14 min hover on stock NiMh battery
10% tail rotor
8% tail boom
hI MAN PLEASE, PLEASE POST SOME PICTURES. i NEED TO LEARN A LOT ABOUT DIY. PLEASE SENT , POST SOME PIC. THANKS BRO
SAMI
[quote]ORIGINAL: rodgermoore2001
SAMI
dUDE YOUR MAIN MOTORS BRUSH IS DEAD TRY REPLACE THE MAIN MOTOR.. MAKE SURE TO DO WITH THE STOCK ONE COZ OTHERS WILL BURN OUT.
Aerohawk:
3 cell li/ion home made
310 tuning motor
piccolo pro paddles
shaft collar home made
hb v2 tail motor
mixer board heatsinks home made
swash plate ball
310 tuning motor
piccolo pro paddles
hb v2 tail motor
swash plate ball
GWS Dragonfly 2003
Feb 27, 2004 Configuration:
2 Cell Li-Poly 1500mAH KoKam
Himax HA2025-4200 (2mm Shaft version) Brushless motor (Main Motor)
Tail Motor = ??? No tail motor.. Damage. Looking for spare.
Brash Shaft Collar (Home Made)
Castle Creation PHX-25 Brushless controller (For Main).
GWS ICS100E (For Tail)
Anti-Rotation Mod (Self Modified from BTT Cupid)
Aluminium Head Stiffener (Home Made from Computer Aluminium HeatSink)
Elevated Tail Section (Aluminium Tubing Mod...Home Made)
Li-Poly Battery Compartment (Home Made from Coke Bottle plastic)
Rubber Duck Antenna (Mod from some junk CB Radio or Cordless phone antenna)
Super-Hornet
Super-Hornet
