Cleaning you T-Maxx
Cleaning you T-Maxx
How do you clean you T-Maxx? I ran my truck in the grass this weekend and it has alot of oil and
dirt all over the truck. I have heard use a air car and just blow it off but that does not remove the
oil. Can you use an engine cleaner like you would for a car engine. Just cover the motor and the
carb and spray the entire car then spray with water to wash off. Is this a good idea or not? It removes
the grime from a car engine and makes it look new again.
NC
RE: Cleaning you T-Maxx
I use simple green on my truck. Just dont get the servos wet or the motor. I use another spray bottle full of water to spray the simple green off. Or you can use air and brake parts cleaner. That works good also.
