Securing Sullivan Gold-N-Rods Outer Sheath
How do you secure the outer sheath for pushrods? I have a problem trying to secure the flexible sheath in ARF models that are covered and difficult to access through the fuse. I've tried drilling through the frame with a long bit and usually end up drilling a hole through the side of the fuse. Anyone have any ideas?
AZ
flyboy2
Somebody out there probably has an easier way, but this is what I have done a couple of times in the past. When you use the long bits, first establish the angle of drilling by marking a reference line on the bottom (or top - which ever is easiest) and sides of the fuse, between the servo arm and control horn. You can use a piece of thread, or simply draw the line on the fuse using a long straight edge and a Vis-A-Vis marker. I prefer the thread method - less cleanup (lazy). This allows you to eyeball fairly accureately the line of the drill. Remove a small section from the bottom of the fuse to access each of the formers(ouch). Then you can install the rod supports to the formers as needed. I use medum CA to secure the outer sheath the the supports and fuse sides. Be sure to rough up the sheath for better adhesion. Kind of a big PIA, but it works great. Hope this helps.
Good question, great thread!
I've removed the wood dowels in already finished planes. You know the ones with threaded ends glued to the long stick
I measure the fuse (on the outside) where the formers are located. I cut a length of 1/8 ply roughly a 1/4 inch shy of the width that the fuse is. I drill holes usually just 2, one for rudder one for the elevator in the 1/8 ply. I put the outside sheathing through the hole and place a piece of 1/2 inch long silicone fuel line tubeing on either side of the support. I do this for three of the formers. After it is all done I have 2 outside sheaths traveling through 3 pieces of ply sandwiched with the fuel line sitting on the bench. Then I fish (pre-epoxied on an angle) the whole assembly down through the fuse. Once your rod supports are just behind their respected former turn your assembly straight and give it a little pull. I have had good success with this method although the first one I did was tricky to say the least. Hope I explained it properly. :drowning:
