Which primer for metal retracts?
RE: Which primer for metal retracts?
If you can get hold of an etch primer all well and good, you can also scotchbrite the landing gear, degrease, I soak mine in very warm water that has got wash detergent in it, soak for about 30 mins then dry. The photo below is a set of Mig 29 landing gear that has one coat of 2k primer and a coat of clearcoat.
Hi John, haven't seen you in a while. Hope you are doing fine.
Be careful when using lock-tite on the retract screws. Over time, it has wrinkled the paint of all my retracts regardless of the paint method.
Jack
Jack
