Heat Blanket
My Feedback: (164)
Heat Blanket
Hi Guy's
I found this at the auto store good for 1100 degres and very light weight and you get 3 ft for about 15 bucks, worth the safety perfect to run wires pass the pipe area
RE: Heat Blanket
"soldering mat" image search
It's quite heavy but will withstand direct flame from a blow torch
http://www.google.co.uk/images?q=sol...w=1296&bih=636
RE: Heat Blanket
go to www.screwfix.co.uk put soldering mat in the serch box i brought the rothemberger one it's two ply so cut the thread around the edges and it's twice the size
NJ
RE: Heat Blanket
You guys should take a look at this stuff, good up to 255c.
way better than the heat blanket.
http://cableorganizer.com/fiberglass/
Alan
Alan
My Feedback: (15)
RE: Heat Blanket
ORIGINAL: DAN AVILLA
Why do you need heat shield when you wont fly them? I guess ground running might over heat something. LOL Dan
Big D has some beautiful airplanes and flying time you would say to each his own…….wouldn’t you?
David Hudson
RE: Heat Blanket
Anyone here in the UK found a reasonable priced alternative heat proof blanket product to wrap around jet pipes as opposed to BVM type stuff?
My Feedback: (164)
RE: Heat Blanket
ORIGINAL: Vinceyboy
Are you talking about the paint on from BV
Dave
RE: Heat Blanket
Hi Dave, no the actual stuff they use to wrap the jet tubes in to protect the fuselage from heat, over here they call it BVM Ceramic Blanket, it's about £13 for a 12x24" piece, don't sound a lot but it is when you need more of it.
cheers,
Vince.
cheers,
Vince.
My Feedback: (48)
RE: Heat Blanket
I ordered mine from Wicks Aircraft Supply. It's the same as the BVM blanket except 1/16" is slightly thicker. What BVM sells is 1 mm. thick. The price is very reasonable, $4.34 per foot off a 24 inch wide roll. You might want to check the aircraft supply businesses in the UK to see if they carry Fiberfrax material.
http://www.wicksaircraft.com/catalog...126/index.html
Joe
Joe
RE: Heat Blanket
Hi,
Two layers of regular ol' Reynolds Wrap aluminum foil, wrinkled up (to make air pockets between the two layers) and tacked together with CA or RTV. That's the best heat blanket I've ever used. It's also the least expensive....
