Soot on car?
Soot on car?
Hi gang,
My Losi 810 has gone through about 10 tanks, and I'm still getting some soot (see attached). While I am probably running it a TAD rich (although it runs/sounds/smells/feels great) I'm curious as to what this is? Could it be possible "debris" from the ground that is sticking due to the nitro?
I'm not seeing anywhere distinguishbly where it's being burned off the car, but it is spread out pretty evenly so am unsure?
See attached pics and let me know your thoughts.
Thanks!
Thanks!
RE: Soot on car?
Thanks. I'm going to take her out bashing this weekened (will post a video). That will give me an idea at how durable she is as well. I've budgeted to replace any dinged up parts that I can't clean like new, and will evaluate the stock clutch then...as I definitely am interested in the M2C three show.
"On-road" this buggy has been very impressive (although the front tires already show a lot of wear). I'll be curious to see how she can beasts off-road. Can't wait!!!
Location: San Diego but living in Dubai, UNITED ARAB EMIRATE
RE: Soot on car?
Tire rubber is my bet, you've said it yourself "although the front tires already show a lot of wear". I'll see that kind of build up from the rubber starter wheel in my starter box.
Do also check the clutch. And honestly, unless your going competitive racing, for the money you'll spend on the M2C clutch, you can get yourself three 3 shoe ofna setups that will be just as good.
RE: Soot on car?
ORIGINAL: tommygun32
However, I am interested in hearing about different clutch set-ups. Proanti recommended the m2c7700 (and that is good enough for me - as I very much respect his opinion)....but am always open to hearing comparable parts at a better price. This will be my first "upgrade" for clutches, so if I can get something 1/2 the price that will have similar improvements - I'm down with that. Can you provide the part number to which you are preferring.
Thanks!
