Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
lipo in f-27B stryker?
Old 03-09-2007, 01:59 PM
rcsindre
Default lipo in f-27B stryker?
hey
can i sett a lipo bateries on a orginal f-27b stryker?
sindre
Old 03-09-2007, 08:46 PM
Matt Kirsch
My Feedback: (21)
Matt Kirsch's Avatar
Default RE: lipo in f-27B stryker?
Yes, you can.
Horizon recommends a 3S 2100mAh pack, or another 3S pack of similar capacity (1800-2200mAh.)
Old 03-09-2007, 11:01 PM
Mayday!Mayday!
Mayday!Mayday!'s Avatar
if you do use a lipoin the f-27b make sure to change the jumper to let the esc know its a 3 cell lipo.
Read the manual on how to do it. All you have to do is remove the jumper.
Heres a pic of the board and the arrow points to jumper 3.
Old 03-10-2007, 01:20 PM
j stumbler
The 3 cell lipo in the Stryker will give you excellent performance. At our local flying field, everyone flying strykers now flies lipos. The 2100 11.1 lipo is perfect, plus it will work great when you go to brushless Watch your cg, and have fun!
Happy Flyin',
Al
[link=http://www.commonsenserc.com]www.CommonSenseRC.com[/link]
Old 03-10-2007, 05:03 PM
rcsindre
i have f-27 stryker, not the B-type. can i put lipo in this fly? And what is diffrent wich F-27B and F-27 stryker?
PS! i will have very fun wih the stryker
Old 03-11-2007, 11:13 AM
Matt Kirsch
My Feedback: (21)
Hmm, that's a different issue. It might work, but unless you're willing to try it, or we find someone who has, there's no way to know for sure. All we can go by is the specs from Horizon, and they only mention the stock pack with the original F27 IIRC.
Old 03-22-2007, 11:33 AM
rcsindre
is not woks that was for meany mAH in the batteries and the regulator smelts[sm=tongue_smile.gif][sm=confused_smile.gif]
Old 04-06-2007, 12:05 AM
XxOoCoBrAoOxX
No, if you have the first issuse of the f27 strykers, you cant. If you have a B stryker, then you can have some fun.
-Adisn
Old 08-01-2007, 05:35 AM
joffen
I have the B Stryker, and LiPos are shipping as I type this. I'm just a bit concerned about the ESCs Lipo compatibility, i.e. the LVC limit. Is this also adjusted to fit a 3s LiPo when I change the J3 jumper?
Old 08-01-2007, 04:15 PM
Mayday!Mayday!
Joffen- If you have the B and you move the jumpers to the correct position for a lipo, then the esc will cut off at the right time. If you use the lipo and do not change the jumpers for lipo use, then you will drain the lipo to low and it will no longer be of any use.
The only issue I ever had with using lipo's in my stock B version was the motor's would give out after a while, maybe 60-70 flights.
Make sure also to use the smaller prop that came in your box when using a lipo. It will help to keep the amps down and will increase the rpm's.
If you look in the manual it will show you where to place the jumpers, and if you don't have one, I posted it above.
