FUEL TANK PRESSURE
MY CAR WON'T STAY RUNNING ALL IS HOOKED UP OK. IF YOU KEEP PUMPING THE PRIMER IT WILL RUN UNTIL I STOP. IF I UNHOOK THE HOSE FROM THE GAS TANK TO THE MUFFLER AND BLOW IN IT , IT WILL RUN TOO ANY IDEAS WILL BE APPRECIATED THANKS
maybe you have your idle to low. Also open a litle bit more the fuel needle. If you still have roplems it means that even your silicone tubes have leak or your fuel tank looses pressure. Then you should buy a racing fuel tank without pump on it for better air compression into the tank. In that case tap the exaust with your finger ant pull the starter 2-3 times in does the same work as the pumb. For further help pm me.
ON, CANADA
ORIGINAL: spedfrek
Ryan
