MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Breaking in the MVVS 160 Gas
Old 04-20-2006, 04:13 AM
wessman
Default Breaking in the MVVS 160 Gas
Hi!
What prop should I use to break in my MVVS 160 petrol? I´ll use MVVS tuned pipe and Menz S 18x6 prop to 3D my plane, so is it OK to use these when breaking it in?
Thanks.
Reggae man
Old 04-20-2006, 05:06 AM
DarZeelon
DarZeelon's Avatar
Default RE: Breaking in the MVVS 160 Gas
Petteri,
In general, break-in is best done with a smaller diameter, larger pitch prop.
In this case, the 18x6 can be used for this purpose.
Remember, fuel does not cool, with a spark ignition gas engine, so just gentle running with higher oil percentage will be best for break-in.
Old 04-20-2006, 05:53 AM
wessman
Hi, Dar!
And using the tuned pipe during the breakin in doesn´t matter?
Thanks.
Reggae man
Old 04-20-2006, 06:29 AM
DarZeelon
DarZeelon's Avatar
Petteri,
I broke-in my own MVVS 26 cc glow engine, with the tuned pipe on it.
A ringed engine needs to be richened below the pipe's boost range for the initial runs.
The throttle can be played with too (no problem with part throttle operation).
For a gas engine it is less important, since the heat is more uniform anyway.
The mixture strength in a glow engine actually changes the effective ignition timing.
A lean-run is an over-advanced ignition, that causes over-heating; not a lack of lubrication, as some people think.
