Proper setup procedure for fastest iddle to full
Hi,
I would like to learn the proper procedure to fine tune my KT 180 G4 for fastest SAFE times from iddle to full RPM and then back from full to iddle.
I kindly appreciate if you can describe the steps to do this properly and what to look. I dont want to fiddle with this parameters without knowing the proper way and end up screwing things up. I have not been able to find anything online on this.
Alternative, if you can point me to a writtten procedure or video that shows this procedure, it would be great.
Thank you
Thank you
Your turbine is already tuned at the factory for this, you should not have to adjust, some people might increase acceleration delay if they are high above sea level.
jorgeelizondom (05-29-2024)
My Feedback: (53)
Hi,
Thank you
Thank you
