90 degree exhaust header
KS
How do you do it or where can you buy it......a 90 degree head pipe for a Magnum 52 four stroke? If I could get the pipe to 90 degrees, the entire installation would be inside the cowl on my Lanier Citabria.
ON, CANADA
RE: 90 degree exhaust header
I also needed a 90 degree bend on the header pipe of my RCV 90. The original pipe had a bend that made the muffler stick out of the cowl.
I used a Dremel to cut the header pipe into three sections of equal length. I then grinded away at the cuts so that when you put the three pieces back together it makes a 90 degree bend. Then I went to a local welding shop and had them TIG weld the three pieces back together. They charged me $20 CDN (about $15 USD at the time). I'm no welding expert, but the ARC welders wouldn't accept the job. They say the arcs will melt the threads on the pipe. They were the ones who told me to find a TIG welder.
The attached picture is the final result. The welder told me instructions to clean it to make it shiny again, but I didn't bother. It has held up pretty well so far.
Juice
Juice
