Removing Titebond from Monokote
VA
Was gluing the tail feathers back onto my LT-40 and some titebond oozed out that I didn't see in time to wipe off. Has anyone found a way to remove dried titebond from Monokote?
Victor
Victor
RE: Removing Titebond from Monokote
Same as J-R, i often use a Cloth soaked with Ca debonder, let it work on the spot, then wipe with a clean cloth, and the spot is gone!
Titebond's solvent isn't acetone, its water!
Try applying a paper towel and water compress to the affected area and waiting about 1/2 hour. Depending on thickness of the glue, it should wipe off, otherwise keep the compress on it. Watch out for warps!
Erik
Erik
