OMP - Ohio Model Products Support ForumDiscuss products and get support from OMP. This forum is operated by the owners of OMP and your support questions or complaints will be handled as OMP deems appropriate.
took the pro yak with the 55ax out today and the wind was around 10 to 20 mph whet a blast,last flight doing a water fall went to pull out and had no elevator control so i cut the power and used rudder to try to slow it down as it went in.only danage was the elevator and stab ripped off will be in the air again this weekend
