zenoah carb
zenoah carb
BOUGHT A ZENOAH 23 GAS AIR (KRAFT-COIL IS AT BOTTOM OF ENGINE) ENGINE AT A SWAP MEET. CAN'T GET IT TO STAY RUNNING, IT HAS A WALBRO 197A CARB ON IT. CAN ANYONE TELL ME IF THATS THE RIGHT CARB FOR IT? THE CARB BLOCK HAD A CRACK IN IT, BUT I THINK I FIXED IT. COULD THAT BE THE PROBLEM OR IS IT THE WRONG CARB? THANKS FOR YOUR HELP
SC
RE: zenoah carb
That is the correct carb.
You THINK you fixed it? How? The resin carb blocks are hard to "fix", it's better to replace a cracked one. Do you know if the carb has ever been taken apart? If so, was it properly reassembled? It's easy to not get it right. How many hours does the engine have on it? It's possible the carb may be clogged and need rebuilding.
It's really hard to diagnose when the only information you give is "can't get it to stay running".
Dr.1
Dr.1
My Feedback: (49)
AZ
RE: zenoah carb
You can buy a brand new carb insulator block wich turns the throttle for straight hookup from Horizon for 11.99,i just orderd one myself.Look under G23 parts listing.Do that first,then post again as to whats happening so people here can help.Is gas in the line going to carb,when you choke or put finger over carb do you get fuel,ect...
RE: zenoah carb
THANKS FOR THE HELP GUYS. WE'LL PUT ON A NEW INSULATOR BLOCK AND SEE WHAT HAPPENS. CALLED DICK BENNETT AND HE SAID IT COULD BE THE DIAPHRAMS. HE'S GOING TO SEND ME THOSE AND A NEW INSULATOR BLOCK. WE'LL LET YOU KNOW WHAT HAPPENS. THANKS AGAIN
RE: zenoah carb
Posting in caps here is considered by most as shouting and somewhat rude, and in so doing you run the risk of having your post ignored by some.
Karol
Karol
