DL50 vs. 3MM53
Old 03-04-2008, 03:13 PM
GhostRider32
Default DL50 vs. 3MM53
Guys,
I'm looking at getting the Edge V2 from WH and can't decide which engine. Do any of you guys have experience with both and can comment on the pros and cons. Please, no brand flaming, just honest fair opinons between the two engines. Thanks.
Old 03-04-2008, 06:01 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Default RE: DL50 vs. 3MM53
Both good, I have the DL it's more powerful, my friend has the 3M it's smoother, you can't go wrong with either.
Old 03-04-2008, 07:01 PM
GhostRider32
How much more powerful is the DL vs. the 3MM? Is it like 100 rpm's with same prop? Will the 3MM pull straight verticle from prop hanging? Thanks.
Old 03-04-2008, 07:13 PM
Truckracer
My Feedback: (19)
ORIGINAL: GhostRider32
Guys,
Have you read the 3mm thread on the Wild Hare forum? Lots of info there.
http://www.rcuniverse.com/forum/m_5547303/tm.htm
I own a 3mm but have not flown it yet .... too much white stuff out there and more comes every 3 days or so. Overall the engine looks very good and appears to be good quality. Mine is mounted in a scale Zero and I chose the 3mm because of its mounting method and carb location. Perfect for short, round cowls. Time will tell how it works out.
Old 03-04-2008, 07:21 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Talk to Tom at WH he will give you the strqaight scoop. I have the WH Sukhoi, it's the same size as my Yak with the DL, the DL is unlimited vertical in it.
ID:	894988   Click image for larger version
Old 03-06-2008, 12:02 PM
frieshoo
My Feedback: (20)
frieshoo's Avatar
I would get the 3mm - Edge combo... Saves money.
I have a couple of dl's, they are strong... I would not mind getting a 3mm one day.
Old 03-06-2008, 12:53 PM
GhostRider32
Thanks guys.
