RC10GT Steering Servo?
Hey guys,
Built an RC10GT a couple weeks ago, and it's been great. Just a question, I'm running an airtronics 94102 standard servo (came with my MX-3) for steering, and it just doesn't quite seem to have enough power for turning. Whenever the truck is under power, it won't turn.
What are your recommendations for steering servos? I've been hearing about the Hitec 645MG, is this a good one?
What kind of strength and speed would you recommend?
Also I'm planning on building an on-road touring 1/10 in a couple of months, what sort of requirements would you recommend for the steering in that one?
It will not turn when you are on the gas because it is lifting the front tires off the ground. Stiffen the rear suspension and weight the front end with an ounce at a time to find the right amount.
Matt
Matt
