OFNA Starter Box Rewiring Problems!
Old 04-07-2024, 04:01 PM
ebucs
Default OFNA Starter Box Rewiring Problems!
I have an OFNA universal starter box. I bought it slightly disassembled, and I'm having trouble rewiring it to make it work. I connected the wires to what I thought were the terminals on the motor (pic #2), but they just sparked and the positive started melting. Never owned one of these before. i've looked up diagrams, but no luck. I've got some pics:
Appreciate any advice. Thank you.
Old 04-15-2024, 03:17 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Get your post count up so you can post photos, or use an image hosting site like Postimg to link the photos. I forget the model numbers of the various OFNA boxes, but I have one that’s all wired up. I did modify mine a little bit as it no longer had a glow driver circuit installed. I added a buck/buck converter to drive the glow plug and run the box on a 4-cell Li-ion pack. I’ll add some photos later today.
Old 04-16-2024, 11:54 AM
1QwkSport2.5r
I got some photos of my OFNA starter box. To correct my last post, I use a 4-cell Li-Ion pack to power the starter motor and a 2-cell Li-Ion pack to power the bucking converter to drive the glow plug.
The blue/red wires connect the bucking converter to the banana plug ports on the box. The short black leads from the bucking converter connect to the battery pack. The rest of the wiring ties the master power switch, pressure activated power switch for the motor, and the banana plug charging ports together. It looks more complicated than it is.
Main view of the inside.
Banana plug ports for external glow driver leads.
Master power switch and banana plug charge ports.
ebucs (04-30-2024)
Old 04-30-2024, 08:57 AM
ebucs
Oh thanks, looks (or looked) very similar to mine. I followed your pics and got it working-ish. The motor was a total weakling for some reason (I used a car battery to power it) and it ended up breaking.
I ended up taking a starter motor out of an old lawn tractor because I'm cheap and don't want to buy a new one (plus the starter motor is much much stronger). Problem is I don't know how to wire it
Old 05-05-2024, 08:03 AM
1QwkSport2.5r
DC electric motors are easy. Wire the positive to one terminal and negative to the other. If motor spins the wrong direction, switch the wires. Very easy to sort out.
Old 05-25-2024, 08:38 AM
ebucs
I know that; it turns out the motor in question was missing something internally. It also needed the ground, key power solenoid, yadayada. I ended up buying a new one.
