Which engine????
Which engine????
which engines are some what cheap and have a lot of power and can use the stock ez start on the revo . and also what are cheap bb kits that are good. heres what i want to put in mine even if i have to use the pull start. will it work with the traxxas big block kit?Ofna Force .26 SG P4 Pull Start
RE: Which engine????
Well, I just put an OS18TM in my Revo 2.5r and I'm exceedingly pleased so far. It was an easy break-in, easy to tune, good run times, and it pretty much wheelies when I want. I'll be glad to get a bit more fuel through it to see when it comes into it's stride.
I picked the TM Because of the OS reputation, the ease of instalation (absolutely nothing to buy except te motor), the fact that I can stilll use the ez-start, and the TM's reputation for good power but not so much that I'll constantly have to be replacing /upgrading drivetrain parts.
ORIGINAL: Revoview
how much did it cost im trying to stay in the $100-130 Range
A BB would not be my choice in the Revo...too much power in my opinion. It's one thing to wheelie when you want and another to have uncontroable wheelies. I want to be able to drive around and play w/o always having to go flip the truck back over.
But what ever works for you.
Good luck.
lol. i just killed my traxxas engine and i said im tiered off trx engines so i just ordered that ofna and a big block kit. i hope it works and the ez start works on it.
PA
Well I would use the heat cycle method as the breakin in method. Do a search --heat cycle and the author would be by fuelman and that will tell you how to break in the engine. Fuelman knows what he's talking about. Just be prepared to read though.
