HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
savage gearchanges
Old 11-08-2005, 10:29 AM
nd_s
Default savage gearchanges
Hello all
I just finished building my savage ss, and have run in the engine.
it runs fine, but i do not seem to hear the car change gears, how do i go about testing if the transmission works.
Old 11-08-2005, 11:23 AM
Stablock
Stablock's Avatar
Default RE: savage gearchanges
How much fuel have you run threw it?
Old 11-08-2005, 11:30 AM
nd_s
i have run about half a gallon of fuel through the engine already.
Old 11-08-2005, 11:37 AM
imukdude
it may take a while to change gear it has to be run in just like the motor but what you can do is go to a large open area on flat hard ground and pull away fairly slowly and give it a little gas and accelerate slowly you should at some stage hear a gear change. if you do not then you will need to adjust the gears as it may be going into 2nd too quick.
Old 11-08-2005, 12:22 PM
alvinl
alvinl's Avatar
You will definitely hear it change gears. It is a really cool sound as the motor drops in rpm's when the gears change.
Old 11-08-2005, 12:35 PM
Geeza!
Hi there, another way to find out if your truck is changing gear:
Start the truck, lift it off the ground by holding the roll bar, gradually increase the revs, if the tranny is shifting, you will feel it.
If your SS is a 4.6 ? i would strongly advise upgrading the 39T second gear to the HD version, with a 4.6 or other .28 it's only a matter of time until the stock gear will get chewed up, and possibly wreck other parts of your tranny
Old 11-08-2005, 01:10 PM
mase_00_7
Trannies dont need running itn, they need an engine to be tuned properly to be able to shift.... i.e. if you're running too rich, then engine wont be getting up to speed and the truck wont be shifting.
Lean the HSN a little at a time until you get good performance with no stutter/cutting out at high speed.
Old 11-09-2005, 06:22 PM
nd_s
i have been leaning it out and it still does not appear to be shifting, any other ideas??
Old 11-09-2005, 06:35 PM
icecreamslick
My Feedback: (9)
icecreamslick's Avatar
Somebody correct me if I'm wrong, but I think that if your idle is set too high, the transmission will not shift properly.
Can you lower your idle screw a little bit? [sm=confused.gif]
Old 11-09-2005, 06:42 PM
12Stones
Yeah mine did that and it was shifting to late so I made it shift earlier and now it doesn't over rev the motor.
Old 11-10-2005, 09:03 AM
gerwen
gerwen's Avatar
If this is a 4.6 SS it is VERY rich to start, i think i went close to 2 turns in before i was approaching a good tune. If you're close to a good tune, you should be pulling wheelies on short grass. By the time you're pulling wheelies it should be shifting.
Don't hurry too much to get into perfect tune. The engine is still breaking in, and will continue to get stronger as you get more fuel through it. You will be surprised at how fast that thing is once you get there.
