Seagull Edge 540 Setup
I'm rebuilding a crashed Seagull Edge 540 and I'm ready to install my radio and servos. Can someone tell me where the CG should be? Also, what are the recommended low, and high control throws?
My Feedback: (67)
IA
RE: Seagull Edge 540 Setup
Hello Bamaham,
I Just happen to have my manual setting right her by the PC
The CG is 3 1/2 inches from the leading edge along the fuse side.
The throws are as follow....
LOW RATE
Ailerons 5/8 UP 1/2 DOWN
Elevator 3/4 UP 3/4 DOWN
Rudder 2 1/2 RIGHT and LEFT
HIGH RATE (3D I think)
Ailerons 1" UP 7/8" DOWN
Elevator 1 1/4 UP 1 1/4 DOWN
Rudder 3 1/2 RIGHT and LEFT
Hope this Helps!!!
NEDYOB
LOW RATE
Hope this Helps!!!
NEDYOB
