ax10 rtr help!!
ax10 rtr help!!
can some one please tell me why my esc on my stock ax10 rtr is overheating after only a few hours of use? and how i can fix it? or where and what one should i get to replace it if needed? i do use a 3300 mah battery if that helps
MO
RE: ax10 rtr help!!
How "hot" is it getting?
Are you running stock gearing? Is something in your drive train binding?
As for a replacment. Check out the Castle Sidewinder.
RE: ax10 rtr help!!
the battery is a 1.2 v i dont know how to find the info about how much its rated for. and it is geared low with a 55t motor, and would i have to run the fan off of a another battery?
RE: ax10 rtr help!!
ORIGINAL: corpestipp
and what is a good replacment esc then for it??? where and what one??
RE: ax10 rtr help!!
i do have a 55t motor with the 14 tooth on it , and yes iam running a standard 6 cell battery. i just put a fan on it using another battery. it seems to help but it makes it way to heavy
RE: ax10 rtr help!!
a good replacement ESC is a Castle SideWinder and it will hadle your motor and batter very nicely and it is only $76 new. Castle makes the best ESC's for crawling on the market and that is not just my opinion that is fact!![8D][sm=thumbs_up.gif]
RE: ax10 rtr help!!
HOLY **** IT WAS THE GEAR MESH THANKS MAN !!! THANKS ABUNCH!!
Glad I could be of help. A loose gear mesh is better than a gear mesh that is to tight. You should be able to see a small amount of space between the pinion gear (small gear) and the spur gear (the big one) I usally just eyeball it but most people put a pice of paper between the gears to get the spacing right.
EDIT****
The truck should roll back and forth with ease with out any power to it as long as your using the stock ESC. ESC's with a drag brake will not do this and is not a good way to test the gear mesh.
Here is a good link you should read [link]http://www.teamassociated.com/basicshub/troubleshooting/stripped_gears07.htm[/link]
and a video tutorial [link]http://www.wonderhowto.com/how-to/video/how-to-set-gear-mesh-on-a-remote-control-car-239621/[/link]
Banned
RE: ax10 rtr help!!
at best the stock esc will work good off a 7c (8.4v) or a 7c (9.6v) max. so if you have a 6c pack at 1.2v per sell you have a 7.2v pack.
the CC Sidewider or the Novak Rooster ESCs are both good ESC and around 80.00 each. you can get the rooster combo (esc/55t motor) for about 100.00
