RS4 Rally Parts
RS4 Rally Parts
Does anyone have a resource for kit parts for the above mentioned car? Most parts are discontinued at HPI and I cannot justify the available option parts to resurrect this car. HPI is loosing its luster for me. I only own 2 cars (RS4 Rally Bought Used, and New Savage 4.6SS) and have either been dealing with parts that can't be found or service department lying about turn around time (1 week turned out to be 3) for an blown engine (my fault).
I just about to give up on HPI and look at another manufacturer.
Anyhow, any help on where to find center pulleys and gear diff sets for the RS4 rally would be appreciated.
CaliberX
CaliberX
RE: RS4 Rally Parts
Sorry about that, but the Rally was released in 1998 and has been discontinued for a while, parts are getting hard to find for that product. eBay sometimes has hard to find parts, you can try a search for the part number you need. The instruction manual is still on the HPI web site, you can reference the part numbers there.
RE: RS4 Rally Parts
I also needed an upper deck. I was able to manufacture one out of aluminium in about 2-3 hours. You need a drill press (a dremel / hand drill can be substituted), some metal files, and a sheet of aluminium that can be purchased at your LHS.
Trace out the outline of the existing deck (glue the parts together if its broken like mine was) with a sharpie, drill outside the line (better to use a band saw if you have access to one). Use the cut-off wheel to remove the bulk of the material.
Clamp the ugly looking thing out of MadMax in your bench vise and file away to the line. The result should be a upper deck that looks and functions just like the original relic. Take good care in marking and drilling the holes for the mounting point, these need to be bang on. You can get away with murder with the outline, however, the holes need to be dead on.
CaliberX
CaliberX
OH
RE: RS4 Rally Parts
ORIGINAL: HPI Staff
any thoughts on doing any direct-distribution to hobby shops, since mine's getting just a BIT worn out and is also starting to see the need for parts.
PS-thank god for RPM's arms and lunsford's turnbuckles and hingepins this sucker's tough
