Digital or not with new Futaba 3PK?
I just bought the new high end futaba and my LHS said I could use standard high torque servos. Well, I installed my futaba S9204's on the streering and throttle. These are used for helicopters and they always worked well for me because they are high torque and very fast. The issue is in the Futaba manual it says use digital servos only. Can I use the coreless BB servos or not? Any help would be greatly appreciated.
i believe if you use the new High speed receiver for the 3pk then at least one servo has to be a digital. If you use the pcm receiver, then you will be fine.
