springs
springs
i'm building my first rock crawler and i was wondering where i could get some long travel springs like on 'the articulator'.
also i was wondering with the clodbuster axles whether it matters if the crawler goes threw water (if it will muck up the motor and servo).
thanks
thanks
RE: springs
ORIGINAL: hilux_guy54
thanks
thanks
Not sure of long travel springs but you can defenitely go through water with your clod, the motors will be fine just might need a good cleaning and oiling after. as far as the servo goes though, better water proof it or it will get damaged in water.
RE: springs
thanks
i was also wondering what the cheapest esc and radio are that will work with the clods with the 4ws.
and the springs still
RE: springs
thanks
thanks
for the radio a traxxas tq3 would be good. they can be found on ebay for as little as 10 dollars with receiver. it can be modded easily with a rear steer kit from http://www.thecrawlerstore.com/ or they sell a tq3 aalready modded for rear steer for 60$
RE: springs
ORIGINAL: lohocla
I use a Moped V16R esc running a mg995 servo front and hitec 645mg on the rear.. I got mine from http://www.crawfordperformanceengine...n/commerce.cgi or on ebay also. its about 30 dollars shipped usually
thanks
thanks
why do you use a different servo on the front and rear
