NEW CLOD
BC, CANADA
NEW CLOD
I recently found out about the super clod and i was wonderin if I bought 1 if it would work on all the affter market Chassisies n parts...,Does it use any of the same parts as the first clod???????
MO
RE: NEW CLOD
ORIGINAL: wolfattak
I recently found out about the super clod and i was wondering if I bought 1 if it would work on all the aftermarket Chassises n parts...,Does it use any of the same parts as the first clod???????
BC, CANADA
RE: NEW CLOD
Alright thanks alot!!
Im lookin to buy a kit and turn it into a crawler. If I get the Super Clod do I need to replace anything other then lockin the diffs? (Such as motors, suspention, etc...)
MO
RE: NEW CLOD
ORIGINAL: wolfattak
You'll need tires, wheels, chassis, motors, electronics, ect...
MO
RE: NEW CLOD
ORIGINAL: wolfattak
that suks. thanks for the info though.
Don't know your budget, but you should be able to pick one up for under $400.00!
RE: NEW CLOD
Those axles are very flexible, and once you get hold of a pair, the options are only limited to your imagination. 3-link, 4-link, stick, monoshock, whatever. You can look around here and also RCC for some examples of other crawlers that have been built for competition and just cruising.
