engine oil/gas ratio for Quadra 42
I got this engine second hand. Presently, I'm using 32/1 gas/oil
mix. Is this the correct mix? Thanks for your help.
Hi,
It'll do!! Were using Silkoline Comp 2 pre-mix and running it at 50:1 and have been doing for many years...the engine still pulls very strong!
The only other advice i could give is to keep an eye on the recoil spring and every so often chuck some anti-sieze compound (copper slip grease) on the spring to prevent it doing anything nasty.
Happy flying
R
Happy flying
R
I used to rum my Q42s on Amzoil at a mix ratio of 80/1. The engines ran fine, and it made a lot less mess than running it at 32/1. One of the Quadras has over several hundred hours on it
I've been using Pennzoil Marine synthetic at 80/1 on my G45, and it's doing just fine, too. But it's only got 150+ hours on it, so only time will tell.
3D_CAP232 is right about oiling the spring. If the spring coils get dry, they will bind, and the spring will break. It wouldn't hurt to oil the clutch, too.
Roger
Roger
