double vision
MI
double vision
Is the manual for the double vision on your web site the current one. The reason I ask is after setting the plane up straight and level to thrust line the horazonal stabs when installed are at 0 degree incidence. If I lower the anti rotation pin it will lower the leading edge. Thus the stab will be at a negitive incidence.
Question should I still lower rotation pin?
My Feedback: (36)
RE: double vision
I aksed Chip the same question on the size of the standoffs for a DA 50 and the thrust line and here was his response:
The short standoffs 1 1/4 are the ones to use and yes lower the LE of the stab an 1/8th inch.
