Nose Gear
Nose Gear
Hi
I've a scratch built composite airplane.
I've this Sukoi tail gear (CLG-124) from TNT Landing Gear
http://www.tntlandinggear.com/store/...nding_gear.htm
I have a simple nose gear up front. However, I noticed that the aircraft was too heavy for the nose gear.
My aircraft weighs almost 25lb. So I was unable to track straight on the runway!
Where can I find a decent nose gear?
I need it to be relatively tall, to match the 10.5" tail gear.
Thanks!
Thanks!
My Feedback: (29)
RE: Nose Gear
Try [link=http://sierragiant.com/prod19.html]Sierra Precision[/link]. Kerry Sterner supplies one of these units with his turbine powered Facet kits. My Facet 2300 weighs around 26# full of fuel and the nose gear has worked great. Since Darrel does custom work also, he might could build you a longer one if his stock one isn't long enough for you.
