RCEXL Single Ignition CDI with 90 Degree Cap for DLE NGK CM6 10mm Plug
- Automatic advancing angle ignition
- From professional CDI manufacturer
- Microprocessor controlled timing
- System is fully shielded
- Capacitive discharge
- Working Voltage: 6.0V-14.4V
- Temperature Range: -40? /+60?
- Suitable for Spark Plug: NGK CM6 10mm
- Application: Suitable for gasoline engine
- RCEXL Ignition systems are designed and built for use with model airplane hobby use only, not for use in any type of man carrying vehicle. Large engine powered model airplanes are not toys. Keep children away and use extreme caution when flying or running engines.
- 1* CDI ignition
- 1* Hall sensor kit (universal type)
- 1* CDI ignition
